Help with GT Designer2 and text alignment
RockSteady
Jul 2008
Kentucky
I'm using GT Designer2 to create OIT layout, and I am having trouble.
I have a Vertical Object displaying Horizontal text. I tried to create the object Horizontally, then Rotate it with the text, however, GT Designer 2 doesn't allow rotation of objects.
Is there any way to make the text align inside the object?
make separate objects (what ever you have that is vertical and text object with horizontal text), lay them on top of each other or any way you like and then group them
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
35
292
118
22
487
188
