Help with Klockner Moeller
Eric Nelson
Apr 2002
Randolph, NJ
4,346
One of my customers purchased a used machine with a Klockner Moeller PS4-201-MM1 PLC in it. The program was gone, but they were able to obtain the original program from the OEM, but only preloaded on a plug-in memory module, not the offline file*. The machine now functions, but not everything works. In order to troubleshoot further, I would need to buy the software and programming cable. Since I don't envision ever needing it again, I'd rather not waste money on this one time project. Never mind having to also learn how to use the software. :rolleyes:
I'm wondering if anyone here knows of someone in the North NJ area that is capable of going online with this PLC???
*While digging around for information, I found THIS POST from Ron Doran (I miss Ron :() talking about not being able to upload without an offline copy. Is this true?
-Eric
Thanks for the replies guys. Can you believe it has been 7 years since Ron's passing (Dec. 2, 2007) :(
Thanks to THIS POST, I was able to get the software, and my customer made up a cable. I successfully connected to the PLC this afternoon, and can view status, etc. with no problem. (y)
Unfortunately, it looks like the 'no upload' is true. I read that the source file might have been saved to the memory module, but when trying to access the memory module, I get the message: "Access to the Memory Card is not possible with this OS-Version" (see attachment). (n)
I get the same message in v5.00 and v5.05. Any idea what this means?
I have good news though! I went through the schematic (Yes! there was actually a schematic!) and found some safety devices that were tripped. After resetting them, the machine now runs!
I'd still like to get online if for no other reason than to make a backup of the program, but at least the machine works again. :cool:
-Eric
Im am trying to decode a Klockner-Moeller PLC program and re code into mitibishi, i have come across a line that i hope someone can help me with...
2,867
Please help me with following instructions l i0.0 = t 44 0.5 what does 0.5 means , i think it is the time and time base but i can not...
2,032
Hi all, looking for some help with an old Klockner Moeller PS22 program. I have a hardcopy of a legacy program that is printed out in the...
4,693
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
21
361
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
166
