help with linmot E400 MT
stu
Aug 2005
England
785
Hi guys
I have a faulty linmot controller which I need to change, but what I need is the set up data off the faulty controller the put on the new controller, I've downloaded the software and have a serial lead to connect, does anyone know how to upload/download to linmot controllers?
Thanks donnacha
I have changed the controller and copied the setting and downloaded to drive the error I have now is multi trigger table error, I've looked at the firmware on each controller one is 1.3.12 and the new one its 1.3.14 will that be a problem? If so how can I change it ? Learning as I go
I had an error on the controller multi trigger table missing, after sitting and playing I came across the curve function which I saw upload and download table so I gave it a go and it worked , I have learned a lot tonight, thanks for your help
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
446
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
167
62
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
542
please help me . I have to make this ladder diagram and I can’t figure it out :(
372
