Joe_Jansen
Safety relays are safety relays for a reason. Force guided contacts and redundancy to be specific. A 4PDT relay is *NOT* a safety relay, and does leave your company open to liability if the plantiff can show that the relay was part of the circuit that was supposed to protect from the accident.
Your best protection against losing a lawsuit is following the safety codes.
Not to mention the fact that if it were your hand at risk of being cut off, would you feel good knowing that the machine builder took shortcuts in the safety system? Is someone's hand worth the money you are saving?
One welded contact, and the whole relay stays closed even after the estop is pressed.
