Help with some suggestions for Logic
Jic222014
Feb 2014
Canada
I’m trying to get some ideas for the logic gate for I can do the PLC after ….
Let’s say I have 3 motors, Motor A, Motor B and Motor C “All could be online, offline”
If I turn-on Motor B first, it is going to be Primary motor.
And If I turn on Motor C next, it is going to be Secondary
And if I turn on Motor A, it should be Tertiary..
If Motor C turned off then Motor A should become Secondary and Motor C will be tertiary even if it is in OFF mode and so on ….
I will have six scenarios
Motor A Motor B Motor C
Primary Secondary Tertiary
Primary Tertiary Secondary
Secondary Primary Tertiary
Secondary Tertiary Primary
Tertiary Primary Secondary
Tertiary Secondary Primary
PLC brand/type?
some hints to get you started, post your thinking and any partial work and we'll help you through it.
hints: you need a way to keep track of starting sequence. Write this logic out in any language or diagram of your choosing then translate it to ladder.
Hello With my background in programming and web development a friend came to me for help building a SCADA system, but I'm a newcomer to HMIs...
1,517
17
258
157
54
Hi all, hope you are having a great day, I am in need of your help to create a AOI or program that does this kind of job: I have a IO Link...
26
488
