Help with TWIDO twdlcaa24drf
Srini1785
Jun 2020
Bangalore
Hello,
I am a newbie here. I work with industrial automation in my professional life and use some simple PLCs along with pneumatics for handling applications. Recently, i picked up a Twido TWDLCAA24DRF PLC along with its cable from scrap very cheep. I was planning to show my son some ladder programming so that he can get started with some simple home automation projects.
While i power it on i get "NCF 344" error code. I am not able to get a error description table from the manual. Any suggestions?.
Good, how do I control through an Analog output of a valve, that is, open the valve from 10% to 10% until it reaches 100%, and then close it...
2,244
I'm having problems with the loaded program on a TWIDO PLC, #TWDLCAE40DRF, the one with an ethernet port. The original one failed and I restored...
5,215
Hi I am new to twido and am looking for some help on where to start with a project i have on. I am looking for a way to input a formula in to...
4,525
Hy guys, Does anyone worked with Twido PLC (TWDLCAA24DRF or TWDLMDA20DTK) and aditional TMI2AMI4LT analog input module? I need help with these...
4,263
Hello Schneider specialists I would like to know the best ethernet driver i should use to connect my twido to my XBGT4230 hmi using ethernet...
8,596
