allscott - I have a clicker torque wrench so I measured starting torque, not running, with reostat at 5 on 10 scale. The motor was peaking at 0.7A starting load yesterday and then settling back to a little over 0.5A running.
I started at 10 in/lbs and got clicks every time until I got up to about 45 in/lbs, then no more clicks. Did it three times and it was consistent. Hope that helps.
milldrone - I had a Linley jig borer for some years (think of a light but precise vertical mill) and used it in my gunsmithing business. It had a Dayton 1/2 HP DC motor and matching controller. It was 90V and drew 9.0 Amps max per the specs. With a 3:1 motor:spindle pulley setup it could pull chips in steel right down to stalling speeds with a six flute counterbore and do it absolutely chatter free (good lube, light feed). So I think I'd like to see how this motor (even though only 1/3 HP and 3.0A) works with 90V before I give up on it. I can and will play with the pulley ratios, I understand the joys of doing that, thanks for the input.
rsdoran - "..If you apply power, turn speed pot to 100%, and start it then 90v should be on A1-A2..."
That is what is happening except that I only get 55V. With the motor not attached, I get 53V and it slowly creeps up to 55V.
The photos - here is the front of the controller with the plastic cover removed from the heatshrink:
Here is the interior, cover open:
Here is the circuit board:
Tell me if you want closeups of any areas. The only trimpots are the IR COMP and MAX SPEED at right center. There is a moveable black wire HI or LO jumper above IR COMP. The wire can be moved to either pin. It is as I got it, on HI, I tried it on LO and it did not change anything.
The reostat in the right cover is marked "3533-0502 625-0338" and was checked with Ohmmeter. Using the center lug as the common and turning the knob, I get 0-4,700 Ohms on one side and 5,000-0 on the other. The two outer legs read open to each other.
Here are the sides of the bridge(?) thing on the back of the heat sink:
That is marked "Gentron PowerTherm 372004, 75030 010984-889". The six 1/4" male terminals on the Gentron are marked:
AC1 G1 -
AC2 G2 +
What next please. :>)
Jack
