Help With Versa Pro !! Please
WOLFTRACK955
Jan 2007
MI
just loaded versa pro and cant seem to get me head around the programing ladders / to build them ??? (brain damage i think )
thanks
You have to build each component of a rung, including the wire.
Each square outline can contain a component. At the top of versapro you should see the contacts coils and somemthing that looks like a T on it's side. That is the "rung wire".
You can also learn the names of the compents and just type the name into a square.
The equvialant of this:
is: H_WIRE NOCON H_WIRE H_WIRE COIL
you dont have a small program with just like 2 small ladders so i can send it to plc to get it to work ?? thanks cory
Hi guys, I need help with position control using a Veichi AC Servo Drive model SD600A1-T2-2R2. How do I know how many pulses for it to rotary 1...
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
36
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
298
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
121
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
488
