Help
EmperorMosta
Mar 2013
Cairo
I'm a student and we were taught about FBD digital PLC programming. I know how to work with digital modules without any problems, but now I have been asked to program an analog PLC module that is simply a comparator that compares between 5 different analog voltage values. I don't know what's the difference or there will be none at all in the programming. The task is to compare them and choose the lowest and the highest values.
I know the difference between analog and digital PLCs, but will that differ in the written code since it's not ones and zeros anymore?! Another problem is that we are not allowed to write codes and just upload them and try them due to some stupid policies. :S
I've been searching the internet all over to get an answer for this without success.
Thanks in advance. :)
The best sources:
(1)The PLC Software Programming Reference Manual for the brand and model of your PLC.
(2) Search on this site for "Xxxxxxx PLC XX-XXX analog inputs", where the x's are the brand and model for your PLC. (Yes, they are not all the same).
(3) Write another post here and state the brand and model of your PLC, and the catalog number of your analog input module. Then someone can give you detailed answers.
My crystal ball is slowly clearing the fog and showing "Siemens" brand.
Hello, I am working with cimplicity workbench, I have made changes to the current project from this machine I am using in the past. However when...
17
Hello, doing switch from FBD to ST. First task is converting my old work. How do you sum variables? For example, Interlock1, interlocl2 and...
140
Hi guys, I need help with position control using a Veichi AC Servo Drive model SD600A1-T2-2R2. How do I know how many pulses for it to rotary 1...
48
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
46
382
