High speed counting on ET200S cpu
ggchavhan
Nov 2006
pune
135
Hi
I have one counter module to be used on ET 200 S IM 151 based CPU.
Please guide me how to count pulses and speed/frequency of encoder.
I have one channel counter module, please tell me what FCs/SFC/SFBs are required to do this. if you have code for above,I will be ever grateful if you could send it to me.
Thanks in advance
GAJANAN
How does everyone count items at a higher speed using a PE? I traditionally just use a sequence to count such as PE gets blocked for a set period...
2,102
Hello, I have a machine that is counting plates and stacking them. I've found that when the gap is too small, the PLC gets the wrong count. Each...
1,855
Hello everyone, I am using a ML1100 and a 2048 pulse incremental two channel encoder. I have set up the high speed counter and the ML1100...
3,199
Hi there guys I once again i need your help as you might be aware i have a long term project running . I am trying to use both inputs 0 & 1 on...
2,434
I have a chance to utelize the 1200 (1762 Processor) I am wondering if anyone has a sample High Speed Counter program, as I started reading the...
4,635
