High Voltage Transformer lockout
Rson
Jun 2017
Michigan
520
I'm hoping someone may have some information.
I'm just trying to educate myself because we will have some projects coming up with some customer equipment. Unfortunately, the customer is not very responsive.
We are using a high voltage transformer (I think several thousand volts) as part of a process that we are interlocking with. It sounds like they have a safety system for getting into the transformer area that consist of a multi-key lockout to ensure anyone inside the area is safe from someone outside of the area from energizing the transformer.
I've done some searching but found no such devices or mentions of this safety system online. I'm hoping I just don't know the terminology and am searching for the wrong thing.
Is this sounding familiar to anyone? Can someone point me in the right direction?
Castell in the UK is what commonly used
http://www.castell.com/en/castell/products.php
One in LV device, one in MV device, released when opened, lock off/tag off your breakers, both keys go in box to allow access to Tx enclosure
Page 10, transformer interlocking:
http://www.castell.com/common/downloads/castell_switchgear_applications_guide.pdf
Hey all, I'm having this issue with an Allen Bradley AC input card(1756-IA16I). I was looking into another issue and found that the inputs on the...
2,984
I am trying to find analog input modules(preferably Modbus/TCP) that can take a higher level analog input. Looking for something up to 16VDC or...
4,361
Hi, I have a 12 lead motor here with un marked leads. I would like to hook the motor up and test but have no idea what coil is what. I Ohm'd the...
9,119
Obviously, it makes most sense to place PLCs into cabinets with little to no high voltage AC (230V & 460V) signals present to help reduce possible...
4,545
I have a question I can't find an answer to. Can I run 24vdc and 480 VAC in the same conduit? Old school thinking us no. I am lookig at motor...
3,101
