Historian SE and OSI PI Advanced Computing Engine (ACE) tags
scotthower
Mar 2012
Pennsylvania
29
Trying to implement ACE calculations on Historian SE 4.0 Advanced Server
  • used the wizard in Visual Studio to create a .dll
  • default point source using wizard was l and then the class name...had to make it just l so that it would be accepted (because of Point Source table)
  • Visual Studio tested through OK - output tag values update as expected
  • used natural for trigger...verified that input tag is changing when scanned every second...ensured that new Historian points have correct range
  • published .dll to ACE Manager - can see that it's running
  • new calculated tags that should be updated via ACE never get updated (still say pt created)
  • server running ACE is 'trusted' by Historian server
  • what should point source of calculated tag be? I made it L...wizard made it a base class...I create a new point with 'classic' class with point source L to test...still no change
I've been looking through OSI support and rockwell support but haven't found any good information on how the points that are outputs from ACE should be setup in Historian.
Thanks!
What's the best method to extract raw data from the FT Historian's OSI PI?
1,424
I noticed that the new FTHistorian 9 only uses the PI 2018 still, and is not updated to 2023 yet. I figured by now any new releases would have...
158
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
139
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
51
Hello Everyone, I want to install and configure factorytalk Historian v6. I'm new to this. Can you kindly share some knowledge on installing...
80
