Hitachi EH-150 Communication
PortmanBlue
Dec 2010
Australia
I'm attempting to connect to a Hitachi EH-150 PLC, the CPU is an EH-CPU104A and only DIP switches 1 and 5 are set on which sets the baud rate to 38400. I'm using a serial to USB adaptor to connect from my laptop to the programming cable to the PLC due to the lack of a serial port on my laptop. The programming cable is wired as shown in this link. I have selected to not use FIFO buffers for the serial to USB adaptor and am using 7 data bits, even parity and 1 stop bit. I have attempted to connect through ports 1 and 2 without success, receiving an error message which says "SendTaskCode failed with error code 0xE8 Receive timeout".
Is anyone able to suggest a solution to this problem? Thanks for your help.
how to read analog calue from analog input module in hitach eh150 using H ladder editor? which register should i read?
1,499
i have plc hitachi eh150 208A and i want to use the analog input but i don't know how to program it using ACTWin .
1,772
i have plc hitachi eh150-cpu208a and i need its programming software version , i tried actwin3.44 but a message error came up "cpu not detected"...
1,727
Hello everyone, I started yesterday to work with a EH-150, this plc is controlling a machine and i want to recover the program from plc so i can...
1,728
I am searching for a programming software for hitachi eh150 . Thank you.
1,324
