HMI Backup from CMD Line RSView
fredz0003
Dec 2010
Houston
186
Hi all,
Does anyone has setup backups on a local network setup using HMIBackupRestore.exe utility in RSView Enterprise. I've setup the CFG file with below parameters;
[HMIServerParameters]
HMIServerName=(Path to project)\HMI Project
I am trying the following from a remote computer in the same local network:
1. pushd \\UNCPath
2. cd (Drive Letter)Program Files (x86)\Rockwell Software\RSView Enterprise\
3. HMIBackupRestore.exe /B (Drive Letter)Program Files (x86)\Rockwell
Software\RSView Enterprise\HMIBackup.CFG
4. popd
I also tried doing the above commands by adding them to a bat file in the HMI, and then running from remote. I know I successfully changed my path in cmd prompt because if I run HMIBackupRestore.exe with a wrong parameter let's say -H it launches an error message popup from the utility itself.
Have you tried with double quote your path?
Also how do you make/control the drive letter consistently, why not use the good old NET USE
Nevermind I figured it. So the problem was that cmd prompt from remote station wasn't really doing anything.
We use radmin for remote viewing so I telnet in, and ran the bat file, and voila the backup was done in the corresponding folder. Now I just need to figure out how to do it remotely will try using P***EC. At least I know that my bat, and cfg for the backup is correct now.
I'm actually using Java as part of a backup utility, it will backup multiple systems, and grab files before we upgrade systems. Doing it by hand is becoming a chore, hence the tool. The hmi is just 1 of about another 35 items or so.
Edit: I dunno why PLCTalk is putting asterisks for P S E X E C?
hello everyone can some one tell me IS it possible to Archive the History data backup of Alarms in HMI. HMI model is GS2107-WTBD in case my HMI...
1,115
Hi, I have a HITECH PWS6600S-S HMI that I need to upload the program out of, and download to a new HMI. Is the programming software free? All I...
1,576
Hi guys, I have Siemens TP170A with touch non-operative. I have replacement but Touch Screen do not work (cannot set Transfer Mode to make a...
2,318
Hiii, guys I need to take backup from esa vt series hmi like vt 310w n vt 170w . Plz tell me how to get it. Also I have vt 5.17 version and...
1,833
Hi guys, How do take backup siemens op270. Do you have any idea please help me. your support and help would be appreciated. Regards. uj
2,658
