HMI - moving location of display
BennieC
Aug 2016
Brisbane
Hi all, first time poster, novice HMI changer.
I've made a change to a display on Factory Talk View Studio, had to make it a little larger to fit in some more data. The problem I've come across is when the display pops up, it now covers the main menu button on the main page. When I test the application, the operators can get to the display that has been modified, but are unable to navigate away from that page.
Wondering what the process is to move the position that a pop up display opens.
I would add a close button to the pop-up.
What version of FT are you using, I remember that in properties you could control where the pop-up opened (as long as the pop-up wasn't the size of the entire screen).
I'm using 8.10. I imagine it should be a simple change, I just don't know how to find where to change the location of a pop up display
Right click the relevant pop up and select 'Display settings'. You can then modify the X/Y positions of the display in relation to the screen...
Regards,
Rob
Hi, I am looking at seeing if we can move our current AB PanelView Displays to the rear mount Weintek MT8070iER1 HMI. We use CompactLogix PLC's...
33
11,066
Hi, I have a Siemens TP2200 and ITC2200 connected via Ethernet to an S7-1214. I have a USB memory stick in the TP2200 and I am logging the...
1,190
73
62
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
87
