HMI tooltip Text
Arvind,
See attached. You need to turn on the 'Tooltip' from the Toolbar settings. I have assumed you are using TIA Portal.
Hope this helps,
Rob
Object > Properties > Misc > Infotext.
If this property does not exist, you can't display a tooltip for that object.
Infotext is limited to objects which the operator can modify.
For instance IO-fields of type OUTPUT, are not able to show this infotext.
IO-fields of type INPUT or IN-/OUTPUT, are able to show this infotext.
127
77
120
76
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
116
