HMI won't keep TIME/DATE??
Nov 2009
Texas
32
I don't understand why after a power loss, when power is restored, HMI reverts back to 1/1/2004 and 12:00:00PM!!!
Please advise...
Using a KTP1000 Basic PN w/S7-1212C AC/DC/RLY
Steve
Hello!
I don't know why this happens but you can use an UPS to supply the power source.
Best regards!
Venix
Pining for the good old days ?
Usually with PCs and PC-like devices, the real-time clock is maintained by a small battery, usually a "coin cell" like a Duracell 2032. Look for one on the main board, usually in a little cage holder. Four bucks will buy one at any drugstore.
This is how it is with all the new panels that dont have a backup battery on board.
You can have the panel automatically read the time and date off the CPU by means of the Date/Time PLC area pointer. You must use the SFC1 READ_CLK to read the clock into a memory for the panel to read.
NB. I do not know if this functionality is supported by the basic panels.
A tip: Be sure to also have a HMI screen for checking and setting the CPU date and time. You need to use the system function SFC0 SET_CLK.
edit: I didnt realise that you use the new S7-1200 PLC. What I wrote is for S7-300/400. I guess that there are similar system functions, but I dont know for sure.
It is anoying isn't it.
I recently had the same experience after replaceing an old OP25 with a new OP277. Tech Sup said the only way is to fetch it from the PLC but as I was connecting to an S5 Processor... No RTC.
I toyed with the idea of connecting the HMI on the factory Ethernet network and fetching time from a time server but I haven't tried it as the customer did not want his machine connected to the network.
Nick
I have a machine with a S7-300 CPU and a TP1200 HMI panel set up for remote support through an mGuard VPN router. I can set up the router...
6,474
Good Afternoon , I have a FactoryTalk View application ( ME ), that I am able to "Test" Run the application on FactoryTalk View and it runs...
7,637
Hi, I'm working with HMI Magelis XBT GT4330. During program download to target machine, communication was interrupted for no obvious reason and...
8,228
Good people of PLCs.net, I am currently working with an HMI that is advantech 1250H, that communicates with a 1769 Compact logix and Currently...
18
Hello all, I know its not good practice to have duplicate destructive bits when writing plc code, but I'm wondering about writing to the same tag...
94
