pieterdwt Member P Join Date Aug 2015 Location gauteng Posts 4 Aug 5, 2015 #1 Good day, Hope someone will be able to assist me. I'm looking for the pin lay out on the Proface HMI programming cable. On both sides (PC and HMI ) its a 9 pin female
pieterdwt Member OP P Join Date Aug 2015 Location gauteng Posts 4 Aug 5, 2015 #3 It is the proface AST3501-c1-D24
nonuke Member Join Date Sep 2005 Posts 840 Aug 6, 2015 #4 Can´t you use the USB Port? If not, just try the standard null modem cable in COM1. It works most of the time.
pieterdwt Member OP P Join Date Aug 2015 Location gauteng Posts 4 Aug 6, 2015 #5 It doesn't have a USB port only coms one and coms two
nonuke Member Join Date Sep 2005 Posts 840 Aug 6, 2015 #6 pieterdwt said: It doesn't have a USB port only coms one and coms two Click to expand... In the specifications it shows one USB port! and two com ports. https://www.pro-face.com/product/hmi/st3000/spec/ast3501_c1_d24.html
pieterdwt Member OP P Join Date Aug 2015 Location gauteng Posts 4 Aug 6, 2015 #7 The usb port can only take a flash drive the port isn't the same as other HMI
