Homework help - glass bottle detection
DLMUK
Jun 2013
Southampton
311
I am after a bit of help please with my I&C HND. I have a question where I need to spec a sensor for glass bottle detection on a conveyor belt - I have found a suitable sensor (retro-reflective Banner Q26) which fits the requirements except for one...
"it is necessary to ensure that a change of sensor state occurs closer to the sensor when a bottle approaches than when it moves away"
It is not specified if the bottle is round or square, however either would be a symmetrical shape. The sensing distance requirement is 5-20mm which suggests to me that every bottle is not in a fixed position.
Could you mount the sensor at an angle?
I'm not exactly sure what they are asking unless they want to sense the approx. middle of the container. If that's the case, an ultrasonic would work better since they are distance based. They also work better if your containers are pressed together and don't offer any space between them.
Did they show any diagrams?
I would use a very sensible optic (photoelectric or laser) sensor, capacitive could also be used, depending of speed, I think a simple arduin sketch with a cheap ultrasonic sensor and a couple of relays could make the trip, havent had the chance to use ultrasonic directly to a PLC
if all bottles are the same size, I would use a emitter-receiver optic or reflective and pont it near the cap, if bottles are not so translucid maybe a diffuse will work
Is this not just referring to normal hysteresis in a photoelectric sensor, i.e if the bottle approaches the sensor it turns on but there is a small travel distance going away from the sensor for the output to turn off again. Sounds like it to me anyway...!
Perhaps they mean you should use an analog sensor. So you could detect an increasing ramp and decreasing ramp. In stead of ON/OFF.
... I need to spec a sensor for glass bottle detection on a conveyor belt
Here's another option:
https://industrial.omron.eu/en/prod...ensors/transparent_objects/e3z_b/default.html
I guess they're asking for an edge detection. I mean, supposing that the sensor goes to high state when a bottle is detected, the logic needs to grant that the function invoked by the sensor (count, put a label) only occurs with the rising edge and not with the falling edge.
I am tryin to create the subroutine that triggers by each second.DN but it's not moving my SQO. Is there anything wrong with my instruction?
4,330
So ive chosen the first option. Is it correct? it would be helpful If i could get an explanation too. thanks
2,281
So I have the following assignment for a class I am taking. "Program overview: The size of the load to be wash is selected first. The start...
2,578
Hi, Slightly off the PLC topic but i'm sure there are people on here with good experience... So I have no practical experience of control valves...
3,397
Hi, I have a question which is about picking the correct size value to regulate the flow of natural gas. I have been given certain values for...
2,044
