fredm54
I'm trying to help a friend of mine who has some Honeywell 620-15 PLCs. They use a 623-60 converter to interface between a laptop's serial port to the PLC's programming port (which I think is a DB-9 connector) This converter has 2 DB-9 male connectors, one to the laptop and one to the PLC.
They believe the 623-60 converter is bad and they cannot find a replacement anywhere (checked Ebay, PLC-Center, etc)
They faxed me a Honeywell Cable Pin Out document that says this is a RS232-RS485 converter but I don't know if the RS485 port pinout is standard. The document defines the RS232 side (1=DCD, 2=TxD, 3=RxD, 4=DTR, 5=S Gnd, 6=DSR, 7=RTS, 8=CTS 9=Blank. The document does not define any of the RS485 pins.
They recently bought and tried a "standard" RS232 to RS485 converter but it did not work. They have several of these Honeywell 620 processors and they tried communicating with different laptops so the problem is with the converter or cables.
Does anyone have any info on this stuff? I don't have one here and he's about 600 miles away so I cannot just drop by to look!
thanks for looking!
Fred
thanks for looking!
Fred
