How to Replace the Batteries in a Honeywell 620-36?
Nemez1963
Sep 2011
Serov
Hello, friends.
I use a Honeywell IPC PLC 620-36.
Now I need to replace the battery in Honeywell IPC PLC 620-36. If at this point I lose the power supply, I can lose the program in PLC (ladder)?
Thank you in advance for all of you.
Hello, friends.
The program in this PLC is backed up by the battery. As long as the main power is on, you can replace the battery without a problem. However, if the power supply fails (or there is a power outage) during the battery replacement you will lose the program.
It only takes a few seconds to replace the battery, it is always possible that a power outage can happen at that moment.
Ok - probably a simple solution to a simple question. My son has one of those remote control helicopters that is putting a dent in my wallet with...
1,888
We have a Beckhoff CP6201 PC and an EK1100 module communicating with it via EtherCAT in one of our machines. Due to problems with the PC, I want...
77
Panelview 2711-K5A8. Customer has 6 of these in service connected to SLC 504’s. One has a bad backlight and I need a solution to replace it...
2,265
I’ve got some devices that are triggered by shorting pins to common. There is 24 volts on each pin and right now I am using a relay output card...
2,595
I can't replace cpu S400 416-3XR05-0AB0 BY 416-3ER05-0AB0 in PCS7 Project when using replace object to keep the original configuration in the...
1,513
