Honeywell ControlEdge 900 PLC Communicating with 900 Control Station
brinocerous
Jun 2018
California
19
Hello, friends.
I've programmed a ControlEdge 900 PLC (900CP1-0200) and I now have to make an HMI application for a 900 Control Station (900CS10-00). The manual I have been reading for Station Designer ("Station Designer Software User Guide" 51-52-25-149) details how to import tags from and HC900, but not a ControlEdge 900. ControlEdge Builder (PLC programming software) does not produce the required *.cde file that Station Designer needs for the tag import. It appears I am stuck mapping my PLC tags to modbus addresses and communicating between the two devices that way. Any Honeywell pros care to confirm or deny?
My take on the ControlEdge PLC is that you are totally correct in your assessment.
If a brand name (Honeywell) on the HMI is not a factory, then there is no reason to use the 900CS model because all the Honeywell features are specific to the HC-900 controller, not the ControlEgde PLC.
I'm looking for a distributor for the Honeywell ControlEdge HC900 PLC but I'm not having much luck. I have a customer wanting a quote for one but...
2,239
Hi Anybody knows how to enter Honeywell HMI config menu. I need to change date and time of HMI. HMI series: Honeywell HCi series
116
Hi all. Would anyone happen to have the Modbus register datasheet for the Honeywell/EnergyICT EIMFlex Modular Meter v1.11 We've 40 of these that...
71
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
115
Hey Guys, I am getting random rack/slot errors. I go to download and everything is ok but then it has a error. For example - Yesterday everything...
371
