Hooking up a Pushbutton SLC 500
gusterminator
Feb 2009
Thunder Bay
85
I'm want to hook up a push button to activate one of my inputs on my SLC L20 Fixed controller. The diagrams that are shown in the instalation manual show a 3 wire field device. Dos any body know where I can find some schematics on how to wire a switch into my controller. it's DC sink input. I was also wodering if I can use the 24 volts provided by the controller or do I use a separate power supply?
Thanks for any help.
It is just a switch, so run your +24 to one terminal, and connect the other terminal to the input point. Connect the 24v common to the DC Common for that point on the input card to complete the circuit.
Using the SLC power supply for field devices is not normally recommended, but folks still do it frequently without problem. The input point is going to draw very little power, but don't go running a bunch of output devices with it, or you may have problems.
Very simple/basic question, but I want to get rid of my uncertainty. I don't think it would be an issue, but when I'm the one writing the program...
1,413
Hi guys, I'm a student starting to study PLC programming and in the class that I am in we don't really get into hooking up to a PLC using an RS232...
3,473
I have an application that has a G310 talking serially to an Allen Bradley Micrologix 1500 PLC. I would like to add a second G310 at another...
4,532
Oh boy! Another HMI design possibility just fell in my lap! I'm stuck on one thing, though... I'm not sure what to recommend for input...
3,108
WE have a ab 5/15 on a compressor when one of the techs hooked a hart475 to a discharge pressure tramsmitter , the compressor shut down on surge...
3,769
