hotwell and coldwell temperature measurement
g.mccormick
Jul 2012
IN
961
I am needing to measure the water temperature in a hotwell and coldwell.
I'm trying to find a transmitter with 4-20ma that I can submerge. Any thoughts? I may end up just using rtd with long leads and putting the transmitter up in a dry location. The pits are 12' deep
long leads is no problem for a converter/transmitter.
it is more depending on the display device.
buy a simple rtd display and a doublepole switch and you have a cheap solution.
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
95
Hi!! I'm looking for Temperature rise calculation software from Rockwell, I just download "Product selection toolbox 2022" but this software is...
221
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
611
I am looking for temperature/humidity sensor recommendations. Would like the sensor to display temp and humidity. Need to connect to a Contrologix...
231
I have an old Chinese Temperature PID controller XMT 8038c2kp that am able to send and receive requests via Modbus poll test center in this format...
444
