How adding AOP in RSLogix5k V19
nightline
Feb 2010
Prinsenbeek
425
Gents,
I've a CompactLogix L35E V19 and a Telemecanique XUW vision sensor.
There is an EDS file from the XUW, and I used the EDS hardware wizard tool to install the EDS file.
Now I like to add the XUW in the IO tree, but can't find the unit in the available modules.
I also looked in RSLinx to see if the XUW is recognized, but didn't see it.
I tried to add the XUW in RSLogix 5000 V20, and imported the EDS file, and the module for the XUW is available in this version.
How can I add this EDS file in V19?
Thanks in advance!
Jack
If they don't have an AOP then they must tell you somewhere how to add it as a generic device. They would provide Assembly instance Input/Output etc.
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
60
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
138
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
174
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
148
Hi Folks. I am gearing up to add a 2nd identical HMI to a project. This 2nd HMI will basically be an exact clone of the 1st one. The equipment...
266
