how can i link RSView alarm sound to PC audio?
briana banks
Jul 2005
242
Hi All
using RSView SE.
Can i link RSView alarm sound to PC audio.currently it makes
only Beep sound.
I don't want to use external device.just use the windows audio.
Briana,
Look under "Alarm Setup", "Severities" for the check box to select the internal bell. If you have a sound card, you may use sounds other than the computer "beep",. as explained in the Help files.
Annunciation
Internal Bell
Check this box to have your computer’s internal bell sound when an alarm is triggered. The computer’s internal beep will sound If you don’t have a sound card installed in your computer, and you haven’t set up the Exclamation event in the Windows Control Panel under Sound. If you want to configure the Exclamation event, use a short sound because when an alarm occurs, the sound is repeated about once per second until the alarm is acknowledged or silenced.
External Bell
Check this box and type a tag name or click the browse button to choose a tag name, to have an external bell sound when an alarm is triggered. An external bell is a sound produced by a horn or some other audio device. The tag name you enter is the tag that is linked to the audio device. It must refer to a bit in the programmable controller.
When an alarm occurs, this bit is set and logic in the programmable controller turns on the bell. When the alarm is acknowledged or silenced, the bit in the programmable controller is reset, and logic in the programmable controller turns the bell off.
You may use U.C.ME-OPC for this purpose. It connects to RSView or RSLinx via OPC. Audible voice files may be played to the PC audio.
In additon, you may send alarms to pagers, cell phones, email and more. A fully functional evaluation version can be downloaded at http://www.controlsee.com .
Mike
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
116
Hi everybody, I would like to know if anybody here has already programmed with a LR-TB keyence on Io Link on a Rockwell PLC? And perhaps have...
94
Hi everybody, Is anybody here still have programmed a Keyence sensor LR-TB2000CL and used it as io link material in studio 5000. I would like to...
104
Hey there friends, recently discovered the world of industrial automation and learned what this fancy PLC can do so i am a super novice. Started...
361
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
121
