How can I make a cable for communication between MP370 ÒÐ and S5-100U CPU103 throug
Valera
Jan 2004
Saransk town Russia
147
From the documentation " The Technical management on MP 370 6AV6591-1DB10-2AB0 page B-1 " mape of pins of connector D-SUB (15pin female) from party MR370 TP as in the table is lower than socket D-SUB
Table B.1 15
Pins-----TTY
1___________Screening (ýêðàíèðîâàíèå)
2___________RxD-
3___________-
4___________-
5___________-
6___________TxD+ -
7___________TxD-
8___________Screening (ýêðàíèðîâàíèå)
9___________RxD+
10__________-
11__________+20 ìÀ
12__________GND (çàçåìëåíèå)
13__________+20 ìÀ
14__________+5 Â/100 ìÀ
How must I do a cable to solder for connection of the panel on IF1A to S5-100U CPU103 through TTY? Must I do like “ To connect one in one contacts of two D-SUB (15pin female) (from party MR370 TP and party S5-100U CPU103) i.e. 1with 1, 2 with 2 and e.t.c.. Or by principle RxD-with TxD-(6 with 9) and accordingly RxD + with TxD + (7 with 2)?? I.e. how it will look?? As in the table is lower or it is wrong??
IF1A MP370 ---S5 100U 15.pin D-Sub connector (both are female)
1___________1 Screening (ýêðàíèðîâàíèå)
2RxD-_______7 TxD-
3___________-
4___________-
5___________-
6 TxD+______9 RxD+
7 TxD-______2 RxD-
8___________8 Screening (ýêðàíèðîâàíèå)
9 RxD+______6 TxD+
10__________-
11__________11 +20 ìÀ
12__________12 GND (çàçåìëåíèå)
13__________13 +20 ìÀ
14__________14 +5 Â/100 ìÀ
This is the picture of the pro face 2301(old) & 4301(new) HMI’s , old communicating with Siemens S7 200 series, and I believe its using comm port...
1,825
Hi Everyone, I need to know how to communicate panel view 600 plus with slc 5/03 via serial cable NC-13 if any body know this technique please let...
2,519
Dear All, I want to communicate s7 200 and proface, so please provide the pin diagram of communication cable. Thanks in advance.
2,743
Does anyone know what software the IDEC FA-2J Controller uses? And what cable is needed to communicate? I can barely find any information on this...
1,135
Hello guys, I need to change the configuration on an C200HW-PRM21 PROFIBUS-DP Master Unit and looking communication cable. Any one knows where...
1,217
