How do i make a programme to run till the end even when stop is pushed
esirioneyibo
Nov 2011
Valkeakoski
Hello guys, please I need help. I am writing a program in Step7 and I need to make the program run till the end before stopping even if the stop button is pushed in the middle of the cycle. How do I make insert the stop to the networks.
This sounds like grafcet or sequential flowchart (SFC) and a 'homework'-assignment
o_O
Maybe like this:
Make a merker that is controlled by the stop- and start-pushbuttons and use this to start and stop your grafcet/SFC.
But to quote you: 'I need to make the program run till the end before stopping even if the stop button is pushed in the middle of the cycle'.
Maybe you do not need a stop-button.:sick: Should you be able to stop at all? Normally yes: maybe you have an automatic-mode, a manual-mode and a semi-automatic mode
You should give us more information. You should also think more about your problem and how you describe it.
Thanks for you comment Ivo.Maenen...
I want to assure you that is it not a 'homework'-assignment as you put it.
I am working on a project which is my final year thesis. I am writing a program to control a recycling machine and I am using SIMATIC S7 as my programming tool.
Anyways, I have been able to figure it out already, so you don't have to worry about it anymore.
Hello friends, I preferred to make a new post because the subject is not the same and I will see in time if my situation is good to put the old...
2,545
A client of mine bought a second hand pavers making machine and did not run it for 5 years.Unfortunately the battery was drained of the Omron...
1,653
1394 Assistance Needed I have qty 8 1394 units in various states of repair that I need to repair and test. 1394C-SJT05-T 1394C-SJT05-T-RL...
2,094
Can someone tell me how to copy programme from one PLC to another with all the data entered in it. e.g. the register values counter limits etc...
1,265
Hi everyone! My name is Vidy, I am having a problem whereby I was wondering on how would I go about trying to program using ladder logic to get...
2,073
