How does one read Scan Time GE 90-30?
It should be on the taskbar, bottom left, along with logic equal/config equal
Critical scantime
If you have a critical time situation. Why not use a timed interupt ? Putt all code that is critical in time in "special" subtoutine and set the triggered scantime.
Maybe not the solution for you or ?
That would be a wonderful idea, except that I am using a very high speed timed interrupt already, this CPU only supports one, and if I try to add the code I need to the ISR, even every 50'th call, the scan time goes to unacceptable levels, if not just faulting out on overrunning the interrupt time-slice.
Have I gotten this right? Examples: SCL uses it's own compiler to make STL LAD & FBD are graphical representations of STL STL is compiled and...
2,936
I am updating a project used panelview 1000, it connected a controllogx, but it not directly read/write controllogix's tag, controllogix map tags...
4,622
Does anyone knows if I can read this ONLINE, is there any archive somewhere? ================================================== ((((((( P L C...
1,865
71
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
76
