How does TTY work?
The_Harlequin
Feb 2011
Europe
30
I know it is 20mA current loop, but I don't understand it. I have a TTY-port like this:
TTY IN+
TTY IN-
TTY OUT+
TTY OUT-
20mA
20mA
If I for an example want to loop this, how should I do? The function I want is if I send ASCII characters on the send line I will receive the same characters on the receive line. Please can anyone explain how it works?
Thanks Bernie.
Two pairs of wires for full duplex - each end has a receive and transmit.
r28g9g.jpg]
C
I have to reprogram some older version Siemens S7 212 (6ES7-212-1AA01-0XB0). I'm using Version 4 MicroWin and the newer USB type of PPI cable...
2,270
ColinJ
C
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
46
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
39
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
125
