How many servo driver can a compactLogix PLC handle?
Tofo
May 2013
CA
57
I have a machine which has 1 keyence optical sensor (digital output) , 3 servo motors (Two rockwell MPL series motors and one rockwell TLY motor) and an Allen Bradley PanelView 1000 HMI. My question is how I can know that the CompactLogix PLC can handle 3 servo motors and 1 HMI.
1. Ask somene next to you who has experience.
2. Ask an application engineer at your Rockwell vendor.
3. Ask here.
LOL thanks for the reply. I am doing #3 now
I just want to see whether anyone in here would know any keyword that I should search in the manual.
Refer to the CompactLogix Selection Guide.
http://literature.rockwellautomation.com/idc/groups/literature/documents/sg/1769-sg001_-en-p.pdf
Before anyone here can help you, you need to give us more details of the PLC and the drives. There are at least 8 different types of CompactLogix controllers off the top of my head.
Older style servo drives were controlled by SERCOS communications, where as newer ones are Ethernet/IP.
Right I should read the literature.
Btw,
I will use Ethernet and I will need to buy the servo drivers too.
TYL motor need to do two position only, so any compatible driver can do
#1 MPL motor will need current control. I need to give a fix amount of force to push an object
#2 MPL motor need to connect a driver with interpolation because I need to read 100k+ pulse per rotation. In other words, it needs to be connected to one of the following ultra3000, Kinetix350 servodrives, Kinetix6000, Kinetix6200, or Kinetix6500.
Good Evening , We have a number of Powerflex 525 Drives . I took notice for years elsewhere and our plant , that our Powerflex 525 drive...
639
Good Afternoon, Just wondering , are many of you using SAP in your plants ? If so , is it difficult to learn ? Are there many training...
1,419
It better to have too many instead of not enough right?
26
2,894
Hi all- I have an application where: - I have a fixed system with a pre-determined, static, network (say, 192.168.2.0/24). - That system...
4,239
I have an application that needs 20 inputs and 20 outputs with only 10 XNOR and 10 NAND blocks. I could do it with relays, but this could end up...
5,172
