How to access AIC+ network
Peacemaker
Feb 2004
22
I am a complete novice on PLC things and I'd like to access PLC program of a control system composed of Panelview 300 and two sets of ML1200 through 1761-NET-AIC. Once I tried AB_DF1, DH-485 using RSLink through 8-pin mini DIN port of AIC+ and COM1 of my laptop for machine troubleshooting. But there was alarm such as "packet time out / check cable". Can anybody help me?
I have never been able to make the RSLinx product group see my point.... That is a DF1 driver, not a DH-485 driver, no matter what its label says.
The RSLinx driver you need to use for your network is called the "1747-PIC/AIC+" driver.
It's not the easiest driver to use because of its heritage in ancient PC's and operating systems, but it is the correct place to start.
Just a quick note to Ken's post:
"1747-PIC/AIC+" driver will work with real COM port only, not USB-to-serial. Some port replicators will not work also.
Try disconnecting your PanelView and then run RSLinx to connect to the PLC using the 1747-PIC/AIC+ driver. Note that when the PIC driver loads in a WIN-XP system, you will get a warning message about incompatibiliity. Just ignore it, click "Continue Anyway" and you should be OK.
I have never been able to connect a laptop to my PLC through the AIC+ when a PanelView or PanelView Plus is connected to the DH-485 network, even using the 1747-PIC/AIC+ driver. I'm not certain if the PanelViews lock up the token too long or what, but I have to un-plug the PanelViews in order to "see" the PLCs, and I have to connect to the PanelView programming port directly to download from PanelBuilder, even if I'm using RSLinx for the download.
Needless to say, this is very, VERY irritating. I have talked to my distributor's tech support about this, and they seem to accept it as just a fact of life in the A-B world.
Come on, Rockwell Software guys, can't you fix this?
As I understand, noone will touch PIC driver anymore.
Because they concentrate on 1747-UIC.
Just wait a little: 1756-DH485 is coming for contollogix...
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
198
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
97
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
626
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
79
Hi all Trying to remotely connect to a TIA Portal PLC. I can ping it without a problem but can't get my software to connect. I've opened port...
355
