How to choose my first PLC?
yairtzur
Mar 2014
Mexico City
I'm about to purchase my first PLC ever.
The use of the PLC will be to connect between some production machine to a manipulator (robot), and also some outside accesories (i.e a piston, an ionizer, vacuum etc.).
The PLC should get input from the machine (i.e mould open, mould closed etc.) and send the appropriate pulse back to the manipulator, but in the same time to get inputs from the manipulator and activate the accesories.
As for now, I don't deal with analog inputs, only 1 and 0s (there is current or there isn't).
Except of the amount of inputs that I will need (from both the manipulator and the production machine) and the amount of outputs I need, to send signals to the manipulator and for activating the other accessories, what else should I consider?
To my understanding, I need NPN inputs (to receive signals from both the machine and the manipulator) and PNP outputs (for sending signals to the manioulator and activating accessories).Is that correct?
What else should I consider? What is better for my needs? Transistor outputs or relays? Maybe transistors and connect them with external relays if needed?
Do I need to worry about the speed of the device (I don't think so)?
What about counter and clocks? I don't see the need of and internal clock rightnow, but is it worth spending more for maybe future applications?
Sorry for blowing you up with questions, I'm a total newbie and have no experience with those devices.
Hope I was clear enough to let you help me.
Thanks,
Yair.
Yairtzur,
The first thing you will need to consider, regardless of the brand of controller is the number of inputs and outputs you will require for your application. Most PLCs are expandable.
If you are interfacing your PLC outputs to relays then it really doesn't matter what type of signal you require.
Regarding speed, you will want to consider processor speed in terms of how quickly the controller interprets code. Based on what you have provided, it doesn't appear that you have anything that would be considered "scan critical"
How fast do your pulses need to be, going back to the manipulator. If it is seconds or milliseconds, a regular output should be sufficient. If you are sending pulses back, then you would need to look at a controller with a PWM (pulse width modulation) output.
Based on a limited number of I/O you may want to consider the FMD series that we resell from Triangle Research.
http://www.eternity-sales.com/tri-plc/fmdseries.htm
If you have any questions, feel free to pm, post, or email me through the link provided in my signature.
Velociraptor, thanks for the link. I'm currently trying to figure out exactly what I need, that's why I'm consulting you.
Stephen - Can you please explain what is PWM?
And another question - as long as I don't deal with sensors yet, Can "convert" NPN to PNP just by using the right symbol (i.e ] - [ or ] /[)? They're just some electric pulses coming out..?
Do I really need PNP or what I need is NPN? I'm kind of lost with that matter...
EDIT:
OK, I think I git the idea. NPN output will only close the circuit but won't provide any power, I need to connect the output accessory to a power source?
Thanks!
The type of inputs and outputs you will require will be dependent upon the devices you choose. A relay is a contact closure.
The symbols you are are talking about, refer to programming for [/] normally closed and [ ] normally open contacts in programming, ultimately determining current flow of the ladder diagram.
I would suggest using some of the information on this site to get familiar with the terminology...
http://www.plcs.net/contents.shtml
Pulse-Width Modulation (PWM) is a highly efficient and convenient way of controlling output voltage to devices with large time constants, such as controlling the speed of a DC motor, the power to a heating element, or the position of a proportional valve.
I am developing a PLC. The IDE for my PLC will be VS Code. I want my PLC to support IEC-61131-3 but only one language with is ST. Actually I...
28
8,014
:yeah:Hi all, We are a small company involved in water and wastewater treatment and have been feeling the need to "upgrade" our standard...
1,947
Please help me to choose plc I have a problem with my plc :shutit: because I can crack the password using another software ( i get from...
2,355
Hi everybody! I'm new here, and I hope you can answer my question! Currently i'm busy with writing a PLC program for climate-control in a...
5,731
I may choose a PLC for an application with 1 Tank, 2 pumps, a PT100, some level switches and an analogue input. I'm thinking to use S7-200, or...
4,027
