how to communicate DTC1000 via DVP 14 ss ( Delta PLC)
just connect delta PLC and delta DTC modules via RS485 port and download the program(in pdf) as i have attached it in previous post.
Why adding 400001
I've connected DTC1000 to a FATEK PLC and I want to read the measured temperature and write it in R2000 for example
A friend said read this file
http://www.deltaww.com/filecenter/P...405/Manual/DELTA_IA-TC_DTC_OM_EN_20160311.pdf
So I saw that the value will go to 1000H which is 4096 in Decimal
But that didn't work and my friend said you should add 400001 to it. It means that PLC software can read data at 404097 and it WORKED. I'd like to know where this has number come from or maybe I'm making mistakes in my understandings
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
39
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
588
We have some very old technology in my plant that needs adjusted but I don’t have the equipment. Can anyone tell me what I need to program this IO...
349
Hi Guys, I want to connect my 1769-L36ERM to a different network domain, is it possible to do it using only the dual ports in the Controller? Or...
226
