how to communicate laptop with s5 software and s5 compaitable siemens plc
amu_bgr
Jul 2006
bolangir
28
hi all
i have s5 licened software installed in a latest laptop with window xp operating system. this laptop does not have a serial port.how to communicate with s5 compatiable plc.
I don't think you can go online with S5 CPU without real serial port. You can try USB to SERIAL convertor.
Basic requirement is that you should have TTY converter for S5 PLC.
Best Luck
If you go on the Siemens website you'll be able to get the updates for S5 to bring it up to the 7.23 version. This version should run in 'windows' mode.
Then you should be fine.
(Even in dos, do your USB ports not work??)
usb is not working in dos. thanks, i will try to upgrade it first.
A production dept desktop and validation dept's laptop both communicate (using the HMI app) to the HMI through a couple local CAT cables and...
6,572
how to communicate FactoryTalk Optix and Mitsubishi Q Series. I want to know the details of that
58
HOW to communicate with OPTIX and Mitsubishi's Q Series PLC?? PLEASE HELP ME
67
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
610
We have some very old technology in my plant that needs adjusted but I don’t have the equipment. Can anyone tell me what I need to program this IO...
372
