How to communication withPLC honeywell IPC 623-60
CHALOEMPHUN
Oct 2006
bangkok
Hi I would like to know how to connect to plc honeywell ipc623-60
for make ladder diagram
please advise me for hardware (how to make or to find it)
thanks for your help
Honeywell recently introduced a Windows based loader for the 620 series. Former versions were DOS based.
Your local Honeywell rep can help you with pricing for the loader software. Part numbers are in the note below.
Here's the Honeywell announcement:
Honeywell is pleased to announce the release for sale of the 620 WinLoader, version 5.4
The 620 WinLoader replaces the 620 MS-DOS Loader. The 620 MS-DOS Loader was an MS-DOS based software that would not function in current Windows operating systems. The 620 WinLoader addresses this issue in that it is fully compatible with Windows 2000 & XP operating systems.
Additional changes are listed below:
- The Terminal Emulator & Utility Functions are not supported in the 620 WinLoader. - Serial printer implementation must be done using the MODE command (described in the user documentation).
- The Append Ladder Logic function will validate the file to be appended and will be appended only if the file does not contain any invalid op codes.
- This release includes a self extractor that will also install the RTDM and UAIM configuration utilities. The RTDM & UAIM utilities are no longer purchased as separate software Known Issues in this release:
- This was not tested on multidrop configuration.
- Inserting an Indirect Sendout instruction without defining a valid register value clears program memory. This is a platform issue and was not addressed in this release.
Ordering: The 620 WinLoader has the following new part numbers.
623-6225 620 WinLoader (complete with converter & cables)
623-6226 620 WinLoader (software & documentation only)
Dan
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
26
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
99
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
40
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
45
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
106
