how to configure siemens s7-300 DI/DO
avremail
Dec 2009
portharcourt
model;simatic S7-300,315-2AG10-OABO
DIO SIM323 D16/DO16*DC24V,323-1BL00-0AA0
Problems, i have configured the CPU and digital hardware as stated in the help,wrote a simple ladder logic,downloaded, and debugged, every things seems to be working fine with all a simple two switch and single output logic. with all the addresses appropriately addressed and, but i still can get an output with a potentiometer or bulb. please what may i do?
Hello Avremail.
Do I understand that the problem is to get the output to power a light bulb ?
You must supply 24V on the terminals 21 and/or 31.
And you must supply a ground that is shared with the ground of the bulb on the terminals 30 and/or 40.
And the bulb must be rated for 24V of course.
You may look in the manual:
http://support.automation.siemens.com/WW/view/en/8859629
hello JesperMP,
i appreciate your suggestions,but i have already done that,seems to be that those addresses are for output,located on my Q4- Q5,i used a +24v dc input with a -ve common with input and bulb, still no output,i even used a potentiometer to check all my output addresses for a dc signal. anymore suggestions ? thanks
With "potentiometer" do you really mean "multi-meter" ?
Anyway, I now reread your post, and are you saying that there is 24V on the inputs, but the output does not change according to your logic ?
If that is the problem, then you can watch the code online with STEP7, and see how the inputs and outputs behave, and what are the conditions to make the outputs change.
You have to write in a more concise way, as it is very hard to understand what it is that you really mean.
Good Morning!! I am trying to configure a siemens s7-300 cpu as an I-Device, to read the data on a GE RX3I PLC. Do you need to do some ladder...
3,351
Hi Sir, I am using S7-300/400. I am usually using FC 03 and FC04 to transfer (R/W) bool values by moving them DBs. However i want to R/W bool...
2,063
Hi Guys I have some issues with profinet configuration Siemens step 7 v5.5 Fanuc robot profinet card cp1616 I have 8 byte safety 16 byte...
2,071
Hello Siemens experts please help me to Configure PP17 panel on Ethernet network in S7-300 CPU315 2PN/DP. I have "S7-300 CPU315 2PN/DP" and...
2,139
hi all i am new here i have a mitsubishi smart touch hmi i.e ms-60t-pe but i cannot find a software to edit and download a program in it any help...
163
