How to connect MicroLogicx 1500 Series LSP to PC
GEORGE D
Supporting Member
Dec 2010
LAKEWOOD, OHIO
35
Hello Colleagues,
Please help me to connect to a Micro Logicx 1500 Series LSP.
The PLC has one port and normally is connected to a EZPanel HMI.
I am using a 1761-cbl-pm02 cable and a converter 1747-UIC.
I can connect to, see it and work with RSLogics 500 with couple of Micro Logicx 1000. But not with 1500 connected to EZPanel.
I remember someone told me that there should be a dip switch to change the settings configurations between PC settings and HMI setting.
Please help me. šŸ™ƒ
Best regards,
George
Thank you very much Mickey,
I will try first to use a USB to serial adapter and the 1761-CBL-PM02 cable with Rslinx using the RS232 DF1 driver.
I will let you know.
Have a nice Evening and a great week ahead.
Best regards,
George
Greetings, I had an issue with a RIO rack 2 and IFM I/O Link dropping on my network. I would loose connection for a second or 2 then they would...
104
Hi friends, i need a help to know the procedure and steps to connect Lenze i700 to PC for parameterize. i tried with lenze easy-starter using LAN...
58
Hi, We have been facing a issue with SCADAPack 474. Configuration is like below. RTU 474 + 6103 PS + 5606 IO Mix Module + 5414 DI Module Only...
76
372
127
