How to define DC Motor horse power?
Charly
Guest
C
We have dc motor with following data (unclomplete name plate):
Field:
Amp: 1.12 Volt: 200
Armature:
Amp: 0.6 Volt: 400
How to defini motor horse power? We need Reliance Flexpak 3000 dc regen drive for above motor.
Any idea?
Thank you.
Charly
The simple method would be to use the 400 volts and the .6 amps to find the right drive. The data sheet on page 6 lists voltage and current. http://www.reliance.com/prodserv/standriv/dc/flexpak/lit/d2882.pdf
You sure it says .6 amps, that would be only 240 watt motor, using simple equations you would divide 240 by 746 which would say 1/3 HP. To explain I got watts by multiplying .6a and 400v which game me 240 watts to obtain HP you use 746watts (which equals 1HP) to divide into 240...ie 1/3HP....a FlexPak 3000 would be overkill for that.
If you are mistaken and its actually 6 amps then you are looking at approximately 3HP.
A motor formual page: http://www.patchn.com/motorformula.htm
hello dear forum, About DELTA DIAView SCADA I defined a variable in Timescript VBscript I want access this variable from within a window For...
591
Hello PLCS.Net! I have the EDS Hardware Installation Tool installed on my PC. When I try to install a file, It says it's successful, the...
2,043
Hi all, I want access a Mitsubishi PLC Q series to SMC. I am using Archestra DASMTEthernet as my server in SMC to connect with PLC. After I...
1,429
Hi, I was wondering if anybody can help me with this issue. I have *.cab backup created from a lower version (Dev Studio 2012R2) and I loaded it...
5,379
Hi Guys, I searched throughout the forums but didnt find any information on this topic. I currently have an application that relies on macros...
1,621
