How to Do Pushbuttons Right
Tim Ganz
Dec 2010
Dallas, Texas
692
Using the tools in this link http://www.alliedelec.com/Images/Products/Datasheets/BM/GREENLEE_TOOL_CO/70160434.pdf
To make 22 mm and 30 mm holes for pushbuttons how is the keyway tool used? I think this key is where the tang of the legend plate fits and keeps it from rotating?
Are all the 22mm and 30mm knockout tools oil tight? What is the difference in oil tight? I guess I have never seen an oil tight button.
How would you keep the keyway punch lined up and square as you only get one chance with a panel door.
If you are referring to the 602XX or 601XX punches, the punch typically has 4 scribe marks on it at 0°, 90°, 180°, and 270° that you line up with scribe marks on your panel This centers the hole and key slots.
If you are referring to the 720 key way punch tool you line it up with your hole after the hole is punched and use it to nibble in a key way.
I'm not surprised. The 720 keyway tool is over $400 list by itself and that's a two step operation which requires a $65 hole punch. The all in one seems like a money saver at that point. I have never used and of those. I use a 30.5 knockout and a file, very carefully. I've never seen a price on the draw stud type keyway knockout. I'd be interested to hear how they work.
I find buying a push button enclosure to be more economical if you look at the cost of labor for layout, knockout, keyhole, debur plus the cost of the panel. I think you come out ahead if you just add a precut box. I don't do a lot of doors with push buttons. If I had more than a couple I would definitely look into waterjet.
Yeah, those punches are expensive. I have a 720 keyway tool but the only time it gets used is if a button has to be added to an existing panel. All new panels are laser cut. Its actually very economical, and most laser shops do plenty of panels and have the cutouts pre-programmed, you just need to give them the locations (get a quote, you may be pleasantly surprised).
Does someone know if there exist pushbuttons directly on Ethercat? I know we could guide standard pushbuttons to a Ethercat IO module, but we are...
776
Good Morning , I would like to start a Powerflex 525 with a N.O. Start Pushbutton , and when the N.O. Start Pushbutton is released I would...
1,691
Hi, Like the subject say I would like to know when are extended or raised operator allowed for a start function. The machine in question...
4,038
Hello, Controllogix 5572 with Studio 5000 v33 and FactoryTalk View SE v12. Is there a way to force I/O bits using HMI pushbuttons? I've tried...
2,901
Hello, When it comes to process control (e.g starting/pausing/stopping a batch or sanitation function) with HMI pushbuttons, what is the...
3,010
