How to find tag links between Weintek МТ8056Т OP and S7-200 in EB8000 Project
alex3110
Mar 2013
Russia
Hello, everybody !
I have a working project for Weintek МТ8056Т Operator Panel connected to PLC SIEMENS S7-200 .
I open the project with EasyBuilder 8000 v.1.34 Build 2008.11.04 or with “EasyBuilder 8000 v.3.45 Build 2010.04.28
There is "MODBUS-server" setting (but not “Siemens S7-200”) here :
EasyBuilder 8000 main window - “Edit” - "System Parameters Settings" window - "Device" tab – "MODBUS-server" string – press “Settings” - "Device Properties" window - PLC - "PLC Type" string .
I want to find a place in the EB8000 project where the links between panel tags and PLC tags are assigned explicitly.
Thanks in advance.
IF the I/O points were assigned tags they would be under Library/Tags/Custom.
There is no requirement to assign tags in Easybuilder so most people do not assign them. They just map the objects to I/O points.
With a way U have indicated (Library/Tags/Custom) only p a n e l tags can be seen , but not PLC ones, because PLC S7-200 has no tag designations like this “LW200” or “LB0” .
IF so most people do not assign them. They just map the objects to I/O points.
- could U explain that in detail.
Tags can be defined for any device that is defined in system parameters.
If there are none showing for your S7 PLC then they have never been defined.
So how then does it work ?
(may be some WEB- references explaining that)
In EB8000 Manual they only explain how to create the internal panel tags (“LB” or “LW”) and there is nothing about external PLC tags.
I have tested every screen and no single screen individually has this fault pop up, but when I compile and send to the PanelView it comes up. If I...
182
Hi, Have a look at this picture... How can I find out the memory address of this tag? It was created by adding it to DB "Data_block_1", but I...
1,064
Is there a way to search the entire HMI program to see if an address is used? I thought we had something a long time ago in ME but I'm drawing a...
1,688
Where do I find the Rockwell Tag Upload Download Tool? I can't seem to find a download link to it, and when I search my start menu to see if it...
6,774
Good Morning , I'm working on a HMI project , and for some reason I cannot find some tags in the Tag Browser. Has this happened to you...
3,011
