how to introduce delay
Ashiq
Jan 2011
Pakistan
hi
dear sir i am using plc S7-300 hardware and Wincc Flexible software for HMI & using PC as a HMI.I connected output to digital output module and control it through HMI.it is working fine.
Sir now i want to introduce delay that after some seconds output is on or after few seconds it should be off.Please guide me how i will introduce delay.
hi look into iec libray SFB4 TON and use that to create your delay
cheers
this is called an on-delay, so you need an on-delay timer
and this is called an off-delay, so here you use an off-delay timer.
Question is, since you used the word "or" in the middle of this sentence, do you need both at the same time or only one of the two. If you would make a timing diagram, it would surely help us determine what exactly you do want to accomplish. Clear questions produce clear answers and drawings are not language dependent.
Kind regards,
Hello To All Well Im Using Omron Cp1l Plc Can Anyone Give Me An Example To Introduce A 500millisecond Dalay. Thanx
2,551
Have a new project and I'd like to get my simulation logic a bit more realistic, as such I'd like to add noise to the simulated analog feedback...
2,207
Hello there, I want to switch on a motor based on the output of the following: If (X LEQ 40 psi) OR (X GEQ 60 psi) Then ... How/where could I...
4,418
I would like to introduce a dedicated forum for ABB control system,this is a really good platform to learn ABB control systems,just like...
1,305
i want the cable to connect PLC FUJI MIREX- F Who ever used, and pls. tell me how i order it , or pls. tell me the part number of the cable thank you
3,932
