kittydog42
How do you wire an MOV or a resistor & capacitor combination to the input to protect it? Is it in series with the input to the terminal? I have an application where every now and then one of the inputs on a given unit will stop working. This particular input is connected to motorized gas valve which probably introduces a fairly high voltage spike on occasion, which causes the input failure. I am trying to figure this out instead of using a relay, because it would be cheaper and smaller than 8 relays. If I go the relay route, I will only add one for this input.
