fishenguy
I'm installing a Pro-face HMI/PLC. Some of the outputs will operate air valves (approx. 3-5 watt coils) that are also controlled by an old Symax 400 plc. I intend to use the same 110vac power supply for both plcs. The company is VERY dependent on the Symax, so I don't want to mess with it.
Should I take any precautions connecting the two outputs together to the same coil?
As I said before, I'll be using the same 110vac power.
I just don't want anything to happen to the Symax output modules.
Thanks for the help. Dave
