How to reset GE CPU374 to factory defaults
cjh
Mar 2003
Cumming, GA
235
Anybody know how to reset the CPU374 back to factory defaults? I figured out how to clear non-volatile memory by shorting out the CLR MEM jumper but that doesn't appear to reset everything.
Getting a lot of strange errors when trying to transfer a project to the unit and I wanted to just reset everything and start from scratch with it.
Thanks!
I'm getting everything second hand (not sitting in front of 'troubled' unit) but they are trying to load a project with an IP address into the CPU but it will give them an "Error 8097: The connection to the device has been lost." and will not finish loading the project (over serial). If they then try to ping the unit for the configured IP address, it will not respond (presumably because the project transfer failed).
I was trying to give them direction on resetting the unit before trying a new transfer. I was testing first with my 374.
The trick about clearing the flash first did it for me.
Thank you.
I am geting error 8097 connection lost
Hi could you please help me where can I hard reset the cpu? Where is Mem Clr? And how to clear the flash using proficy machine? Thanks
Hello, I still do not have equipment in to test. But the RTAC ladder does not have a timer reset coil. I wonder if a reset coil on Timer.IN is...
107
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
46
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
374
I was loading a program onto an XE1e2 PLC and it got stuck on these two windows and won't progress. It won't let me connect from the PC to reload...
95
Hi all, i have recieved some 4RF Aprisa SR+ ethernet radios from a customer to configure. Issue is that they are used and have non-default...
104
