How to unlock GE Fanuc Machine Edition Ladder Blocks?
mduko
Feb 2010
Phil
I have a .SwxCF PLC project file on Proficy machine edition v5.5. Some ladder blocks are in "View Lock" mode and we could not access them. The original programmer, instead of giving the password to unlock the "View Lock" of the blocks, sent the following files:
filename.PKO
filename.PKL
filename.PKA
filename.PKC
filename.PKR
How are the above files used to view the locked ladder blocks?
Appreciate the help guys.
Those are the backup files created with Logicmaster software. Logicmaster included a utility called "PKZIP" which was used to make compressed backup files. Using Logicmaster's "Restore" procedure you can recover a Logicmaster file which, presumably is not viewlocked.
If you don't have Logicmaster, send me a private message and I'll give you an email address where you can the files to me. I'll open them and create a text file of the ladder listing for you, unless the Logicmaster file also turns out to be locked.
Hi ALL I have a problem. I need to unlock the View Lock password on some ladder block on GE-Fanuc 9030. Any help would be greatly appreciated Many...
3,999
Hi, I am trying to download program into PLC but old and new program have diff safety signatures. I guess I am supposed to unlock PLC and delete...
4,316
I am facing a Proface HMI device with password protected, the device is not allow for me to backup the graphic unless I key in the correct...
1,003
How to unlock Hitech HMI upload file *.AA6? I can't reconstruction without this password.
17,592
Hi experts, I have seriously problems with my step 5 backup. Almost all PB blocks in my ST.S5D file has no logic that I can see. I try unlock...
2,080
