I cannt access Microsoft SQL server to Intouch
cassidy387
Nov 2018
BKK
I've tried following "Wonderware InTouch HMI Supplementary Components Guide" but the value from sql not appear on intouch runtime screen.
I connect MS SQL server in SQL authentication.
action script
resultcode = SQLConnect(ConnectionID1, "Provider=SQLOLEDB;UID=tha;PWD=12;Initial Catalog=WSP;Data Source=WIN-L5BCJAA06OD;");
resultcode = SQLSelect(ConnectionID1, "Table1","Table1","","");
resultcode = SQLFirst(ConnectionID1);
"resultcode" tag name type is Memory integer.
"ConnectionID1" tag name type is Memory integer.
help me please, I dont know what to do.
Yes. Look at that while you are trying to get the sql info. It will usually show some info. Also, have you created a bind list?
I’m not sure if this is relevant, but maybe try using “user ID” instead of UID and “password” instead of PW in the connection string. That’s how I have mine in a test set-up. I get errors if I try “UID” or “PW”.
it still not working.actually i also try "database =..." instead "Initial Catalog=..." but it still not working either.
That’s odd.
Try adding this to the beginning of the script:
LogMessage(“The Connection Script is Running);
That message should show up in the log viewer when you run the script. If it doesn’t, maybe script isn’t actually running for some reason?
That’s odd.
In action script?
Actually same what i mean is same problem but the problems are increased in log viewer.
Yes. Try the logMessages in your action script.
Try putting LogMessage(“the sqlConnect is starting”); before your sqlConnect portion.
Try putting LogMessage(“the sqlSelect is starting”); before the sqlSelect portion.
Try putting LogMessage(“the action script is at the end”); at the very end.
Those messages should be showing up in the log viewer.
Ok i will try and tell you later now Its 3:00AM at Thai
Thanks for helping me :)
Is it will help ? Or just showing the message?
Hi I am confused , if i have made some mistake.I am using siemens S7 PLC. I wrote a program in FC and moved some data to a DB memory location...
1,568
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
174
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
87
I have to provide remote access and control to a touch screen. I was thinking about using Weintek and the Weincloud. Does anyone know if this is...
606
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
73
