I need help with operating three channel locks in a river...
testsubject
Feb 2004
Chicago, Il
839
Just kidding guys.
This is one of my problems in my Logic Design class and since all the other students get to post their question I thouight i should at least get one in here. :)
College life is agreeing with me. The logic design class is pretty cool. Over the years, I have always done my programming pretty much intuitively, but I can definitely see myself starting to use truth tables a lot in the future.
Java is pretty easy so far also. Although truthfully, I feel once you master one programming language, it is not too hard to pick up other ones.
I know I have not posted too much recently, (my electromagnetics lab class is eating up a lot of my free time re-learning things I forgot) but I will come up with a way to pay Eric back...<snickers maniacally> Good pic by the way. My daughter said that I really should make it my new avatar :D
Take care guys,
Bob
Deck Hands need Automation, Too!
First get three different sized chanell lock pliers.
Get two actuators for each. One to open / close each plier. The second to shift the one jaw for larger or smaller opening.
Inputs
Open
Increase opening range
Decrease opening range
Close
Plier Select - Small
Plier Select - Medium
Plier Select- Large
Level sensor, in beer mug
Emergency Stop
Outputs
Jaw open solenoid
Jaw close solenoid
Range - larger solenoid
Range - Smaller solenoid
Rotate to large pliers
Rotate to medium pliers
Rotate to small pliers
Low beer level warning lite
BTW Listen to your daughter, she knows a good avatar when she see's one.
Going to get her a plcs.net tank-Tee?
Going to post the picture?
regards.....casey
106
68
383
197
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
95
