I need help !
TonyC1190
Aug 2011
Fresno
im having with 3 Ladders and Truth Tables can some1 help me
here are the problems
X=AB+C the A is a NOT
X=AB(CD) AB are NOT
X=ABC+D B is NOT
and with the Truth tables
someone help please !!
A is NOT what?
A is NOT a grizzly bear? It is NOT a car park?
If you still having trouble with absolute basic Boolean logic to of the AND / OR variety after reading the linked wiki article, you should choose a different career path.
this is what you need to do.
1. set up the truth tables using the following a, b, c, a not,
b not, result.
2. write down a, b, c.
3. then write down the opposit values for a not, b not in the
table.
4. solve your logic using the anot, b, c logic.
5. this has always helped me in the past.
regards,
james.
First One Should Look Like This
Here is a method to do the first one. You can use an Excel spreadsheet to calculate the result of any Boolean expression.
  • Truth Table NotAB + C.xls
116
76
393
200
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
95
