I Need serial ports for barcode scanners
Automate
Aug 2004
Sydney
38
Hi guy's I've got a project coming up soon where I need a couple of fixed serial barcode scanners and be able to read both at the same time + a panelview. Is there a module for the SLC where I can add a couple of serial ports in the rack or do I need some sort of stand alone module.
Currenty I'm thinking that a 5/03 is what i'll be running with the DF1 (Channel 0) connected to a panelview 550 and I'll need some other form of serial input for the barcode scanners.
Any Idea's would be helpful!
For Bar Code Readers I normally use serial modules on DeviceNet. The PointIO modules are OK and relatively inexpensive but need to be mounted inside an enclosure. I normally use Escort Memory Systems CM11 modules which are more expensive but are very robust and do not need an enclosure.
Andybr
I am replacing a non functioning e.w.o.n cosy 141 that is converting serial communications of a compact logix to ethernet. Any recommendations on...
6,321
i want the serial for CX developer and Simulator for omron plc CP1E V1.9. CX developer is getting installed without key but simulator wants the...
2,754
I need a new laptop, but found very little that still have a real serial port. For the Siemens Step 7 software, is it really necesarry to have a...
7,412
I just found out from a Dell rep that the Dell D630 and others are due to be replaced. The new models will NOT have serial ports. They are...
4,175
Hi, all. I just got an Omron CPM2A off eBay and I need to make my own serial cable to connect it to my computer for programming. I will be...
12,344
